How to convert Human Manikin made in Catia into igs format?
I have made a human model using CATIA V5 and i need that model for mesh generation and analysis. But the human is saved in CATProduct and for mesh, it needs to be in "igs" format? How can i convert it then?
First create your human model.
Use the simplification function under DMU and save the simplified file as a .model file (instead of a .cgr file).
Then open the .model file and copy/paste the .model solid into a CATIA V5 .CATPart file.
Then save the .CATPart file as a .igs file.
This should work for you.
