how to create specified layer mappings for dxf files for lasercutting
I would like to find out if there is any way to make correct layer mappings for dxf files from solidworks files
sample :
- convert outline geometry to layer 1
- convert inside geometry bigger as 10 times the sheet thickness to layer 2
- convert inside geometry bigger as 5 times the sheet thickness to layer 3
- convert inside geometry bigger as 2 times the sheet thickness to layer 4
- convert inside geometry bigger as 1 times the sheet thickness to layer 5
- convert inside geometry bigger set as text to layer 6
- convert inside geometry non closed to layer 7
- convert outside non closed geometry to layer 8
why layer mapping ?
- generate the possibility to do automatic tooling on cnc machines
- software like cypcut / Vcarve / cutleader / fastcam use layers to add tools and cutting parameter
