How to import dxf files in solid works and how it will extruded.. Chetan Ambekar 17 Aug, 2016 09:35 AM Actually i can import but not getting extruded part 2 Answers Robert H. Answered on 17 Aug, 2016 03:48 PM If it is a 2d DXF, like most of them are, you will have to use the imported dxf as the basis for a sketch or sketches to generate your own extrudes and whatnot. Hakan BAĞIR Answered on 30 Dec, 2020 06:40 AM try overkill to erase overlapping objects. joining objects (lines, arcs, etc) into a closed polyline is a better way to extrude in solidworks.
