How to do the chain component pattern muhaimin shah 9 Jan, 2021 02:52 PM I was trying to do a chain component pattern, but (all segments of the profile must be tangential and they should be of one contour only) when i pick the sketch Capture.PNG Accepted answer Xavier Answered on 11 Jan, 2021 02:09 PM Go to : Tools -> Spline tools -> Ajust spline. Then you will have to select every section of the sketch Your problem should be fixed this way ;) 0 Other answers
