How to draw frame of a baja vehicle in catia? Bharadwaj bannu 10 Jan, 2019 02:41 PM Actually i did using rib command,but the main problem is the trim is not working. Is there any other command to do the frame? 2 Answers Ananth Narayan Answered on 10 Jan, 2019 03:49 PM So, rib is a solid based feature, but trim is surface based feature. Which means that you cannot use trim for solid bodies, but can be done for surfaces. Jack K Answered on 10 Jan, 2019 10:50 PM A picture of what you've done so far would be very helpful. Have you considered using the Structural Design workbench for the frame?
