How to fix ERROR : Failed to trim weld member or apply a gap because of geometric conditions.
Hi,
I trying to make a structure using weldment, SOLIDWORKS. but at the some joint points profiles collide and solidworks says (Failed to trim weld member or apply a gap because of geometric conditions.)!
I using 2015 X64 edition.
picture and file attached.
thanks.
EDIT :
I think its happens where lines connected to arcs. so I upload part 2.SLDPRT model and some screen shots.
Accepted answer
I think there is 2 solutions for you:
- First, you could construct the frame by Structural Member command and then trim the joint by trim/extend command
- Second, change the sketch on each group on Structural Member command (see attach file)
Hope it could help you
1 Other answer
What command do you use? I think It's still fine with your structure. When I use the Trim/Extend command, It's good to trim the welded frame and add the weld GAP
