How to flatten a Sheetmetal hem to find the required size of the flat sheet.
I am doing a concept test here as the project file is much larger.
The hem on the attache .part file flattens but ends up much much shorter than it should. It is like the flatten tool is not calculating the Bend Allowance properly.
Any tips on how to create this profile and have it flatten properly?
4 Answer
The problem in your piece is very simple, a piece with those curves never do it in several sections, with a single sketch is more than enough, that way can detected the length in flat, I leave an example and hope you serve.
