Is it possible to turn a SLDASM into a SLDPRT?
I downloaded a part and I dont belive that it is a part because it is very complex. Is it possible uploader turned assemly into part?
4 Answer
Sometimes I use that simplest option to save an assembly as a part file to prevent it from being misused or from getting rebuild errors on certain parts within assembly, the result is a solid body that will not blow up and will not make trouble and is usable as it is within other, larger assemblies, for example, a bicycle wheel :) Assemblies can also be saved as jpg files, 3D pdf and other formats...
