Is it possible to convert a Solid Edge file into a Pro-E file? Swamini Chopra 1 Apr, 2013 03:41 AM I have Pro-E Wildfire 5.0 version and need the drawings in that format only. 1 Answer Thomas Fochler Answered on 13 Apr, 2013 01:02 PM Hi, 3D files are easy to convert via STEP, IGES or SAT. 2D drawings are tricky. Normally you have to export them into DWG or DXF an import them in the application needed. Hope this helps. Tom
