Is there any other alternative design for Arbor press instead of using rack and pinion gear? raghu 22 May, 2012 04:13 AM I have downloaded Arbor press of rack and pinion mechanism, but i want to know other alternative method of pressing mechanism other than using a gear. 3 Answers Aled J Taylor Answered on 22 May, 2012 12:07 PM You could use a lever, a cam or a screw. WDS has many clamping components that could be utilised to make a press. Eng Hyd Answered on 22 May, 2012 05:19 AM yes you can use hydraulic piston instead of both rack and pinion, and also worm gear you can use there Kamyar Answered on 13 Apr, 2015 09:56 PM Try Schmidt arbor press site. They have CAD files too.
