pls help me to solve this proble.when am opening a catia file having one geometric set inside it.it is going far away from the axis system.how can i make that component(which is inside the geometric set)origin to axis system origin?) kripesh m 18 Feb, 2013 03:41 PM i have uploaded the cati.part file here.pls help me thanks in advance Handle_FIRST_FORM.CATPart 1 Answer Chris Shakal Answered on 18 Feb, 2013 09:07 PM You can use Translate and Rotate commands to move the part to the origin. I moved it for you in the file. Handle.CATPart
