The shaft is 35 mm diameter, 80 mm long, and fits in a 50 mm thick hub. It is a H7/k6 type and uses a tapered wedge with a cutter tip.
The shaft is 35 mm diameter, 80 mm long, and fits in a 50 mm thick hub. It is a H7/k6 type and uses a tapered wedge with a cutter tip. How to draw?
Draw it normally but you have to write down the fits/tolerances on your drawing
