ANSYS Tutorial :Stress and deflection analysis of a simply supported beam at point load using ANSYS 2022
Beams are traditionally descriptions of building or civil engineering structural elements, where the beams are horizontal and carry vertical loads. However, any structure may contain beams, for instance automobile frames, aircraft components, machine frames, and other mechanical or structural systems. In these structures, any structural element, in any orientation, that primarily resists loads applied laterally to the element's axis would be a beam element.
