Can I performe a swept cut with solid bodies in SW?
Here is the tutorial.
Start SolidWorks.
Select Top Plane and Sketch.
Make a Rectangle.
Extrude it.
Click OK.
Select Top face of the box and then Sketch.
Choose Normal to.
Draw a spline.
Exit the sketch.
Select the right face and then sketch.
Step 11:
Normal to.
Step 12:
Draw a circle.
Step 13:
Isometric view and some zoom to the circle. (Don't exit sketch)
Step 14:
Choose the center point of the circle and the spline. Then choose pierce under property.
Step 15:
The circle will move to the end point of the spline.
Step 16:
Exit the sketch and choose swept cut option in Feature tab.
Step 17:
Choose profile.
Step 18:
Select the circle as the profile.
Step 19:
Choose spline as the path and click ok.
Step 20:
You are most probably done.
