How to do a Basic Linear Finite Element Analysis in CATIA V5
After this tutorial, hopefully you will be able to do a simple linear analysis using FEM (Finite Element Method).
The steps are straight forward and the part used is available in my profile (foot peg - ATV).
The idea behind this is seeing how it reacts to a Pressure of 125 KPa.
All the units in this tutorials are in the IS (International System) but i will put the conversions Metric-Imperial.
IF YOU HAVE ANY DOUBTS SUCH AS WHERE ARE THE COMMANDS LOCATED DON'T HESITATE TO CONTACT ME.
Pedro José Silva Campos
1. OPEN FILE
First, open the file on my profile called "foot peg - ATV".
2. SET UNITS and ADD MATERIAL
Set the units either to Metric or Imperial.
Set the material to Aluminium. -
3. START LINEAR WORKBENCH
Start a Linear simulation on the top left.
4. APPLY CONSTRAINT AND LOAD CONDITIONS
In this case we will use a clamp (full constraint) and apply a pressure of 40 psi or around 175 KPa.
You do this by selecting distributed load and restraint commands on the right (separably) and then the faces you want them applied to. -
5. SET MESH SIZE
Select Nodes and octree mesh. Press twice and then set size and absolute sag.
In this exaple let's only use linear type elements.
(In order not to elongate this tutorial to much, if you more info about SAG and parabolic elements please contact me). -
6. RUN THE ANALYSIS / COMPUTE MESH
Press Static Case on the tree and let the analysis run.
Then click close.
The analysis is now complete.
All that is left is to visualize the results. -
7. VISUALIZING THE RESULTS
View the mesh look and then the different options of visualization.
8. RESULT 1: SEE DISPLACEMENT IMAGE
9. RESULT 2: SEE VON MISSES STRESS IMAGE
10. RSULT 3: STRESS TENSOR PRINCIPAL
