How to draw Hexagonal Nut In NX Unigraphics?
In this tutorial I will show, how to draw a simple hexagonal nut in NX Unigraphics.
Start your NX xx version you have!
1.Then click on New file.
2.click on Model
3.click on sketch
4.select plane
5.draw a hexagon of appropriate size
6.finish sketch and extrude it
7.click on hole command
8.select point at which hole should be
9.do the hole
10.Click on thread command
11.select hole face and give thread dimension
12.You can chamfer edges by revolving triangle sketch
