How to create hexagonal nut in solidworks in simple steps
This tutorial explains how to create hex nut in solidworks in simple step.
  1. Step 1: Selection of plane and basic sketch
    Select the top plane and sketch on it
    As we are creating M20 nut, draw two concentric circles.
    The inner circle will be of diameter 20 and outer circle will be of diameter 20*1.5=30. (For smaller diameters, you can take the multiplier up to 2)
  2. Step 2: Extruding the sketch
    Select Extruded Boss
    Extrude up to 15 mm and click ok.
  3. Step 3: Adding chamfer
    Add chamfer on both sides of the part
  4. Step 4: Creation of hex shape
    Select the top face as shown in figure
    Sketch a hexagon using polygon command
    We have convert outer edge into drawing, so go to convert entity and convert the edge
    Go to extruded cut and select following contours.
    All the contours between the hexagon and outer circle should be selected.
  5. Step 5: Apply thread
    Go to thread option
    Select the lateral edge and end condition and set the parameters as shown below
  6. Step 6: Rendering
    Apply the appearance on it. The final product will look like this
