how to model a nut in catia and show design intent
10 simple steps
    1.create a sketch on xy plane
    2.create a pad and check mirrored extent
    3.select hole wizard and set extension type upto next and click position sketch
    4.postion the sketch to centre
  5. Step 5:
    5.change the dia to 60mm
  6. Step 6:
    6.select zx plane. make sure you see all 3 faces of the nut(the trick here). create the sketch
  7. Step 7:
    7.go to groove option and select the sketch and z axis at their respective tabs
  8. Step 8:
    8.select groove from the model tree. now go to insert select mirror command
  9. Step 9:
    9.select xy plane as mirroring element under mirror tab. warning tab pop ups click yes
  10. Step 10:
    10.your model is ready
