How to use helical sweep cut to make threads in Pro-E\Creo ??
Ok lets get started...
Used a simple bolt....
    Go to insert and select "helical sweep" -> "cut" option....
    A dialog box will opens with a menu manager....
    Now we will keep everything in "default" state as selected by software.See the menu manager.(you can make threads right/left handed,variable/constant pitch etc..)
    Press "done".....
    Nextly select a plane on which sweep profle has to be made...
    or select a plane passing through the axis of the bolt....
    Select "okay"....
  5. Step 5:
    Its looking for a reference plane..select firstly the sketch view and then the reference plane(in this i've selected plane on the fastener)....
  6. Step 6:
    Firstly make centre line.....
    Now start sketching the length of thread(defined by length of line),depth of cut(defined by distance of line below the bolt surface)....
  7. Step 7:
    enter pitch value........
  8. Step 8:
    Make the profile of the cut to be made........
  9. Step 9:
    Select the side from which material is removed.......
  10. Step 10:
    done.........cheers
