Tutorial - Modeling variable spring in Creo Elements aka Pro/E?
Here is the tutorial.
    Insert >> Helical Sweep >> Protusion.
    Keep pressing middle mouse button for default setting and select Top plane when it asks.
    Draw a center line about the vertical axis.
    Draw a spline.
  5. Step 5:
    Exit the sketch and define the pitch value.
  6. Step 6:
    After defining the pitch value define the cross-section of the spring.
  7. Step 7:
    Exit the sketch and click OK in property - manager.
  8. Step 8:
    We have the spring generated.
