Tutorial - Modeling Cutter in Creo Elements aka Pro/E?
Here is the tutorial.
Sketch >> Top plane.
Draw a circle.
Extrude it.
Choose Slant Rectangle.
Draw it.
Exit the sketch.
Axis tool.
Select the circular face.
Extrude the sketch and remove material.
Step 11:
While selecting the cut feature click Edit >> Pattern.
Step 12:
Change the type to axis.
Step 13:
Select the axis created as the axis about which pattern is to be created. Increse the number of instances and click complementary angle.
Step 14:
Click OK and the cutter is generated.
