how to use loft cut in cylindrical shape
In this tutorial you will learn how to use:
revolve boss
extruded cut
sketch on flat surface
loft cut
create new plane
Actually to cut the shape of the cylinder is quite complicated. With this tutorial, hopefully it can help you. You can refer attached picture, and all dimension that needed is there.
