How to use the flex tool?
Here's the Tutorial.
Start solidworks.
Sketch>>Front plane.
Make a box.
Extrude it.
Now you have the part for flex.
Insert>>Feature>>Flex.
Under flex choose bending and input body choose the box.
Change the angle value to 50 degrees. We don't need to adjust the planes because they are automatically adjusted.
Click OK. Now you can see the flexed body.
Edit the Flex1 feature.
Step 11:
Change the flex type to twisting. Keep the same angle value and click OK.
Step 12:
You can see the twisted body.
Step 13:
Again edit the feature and choose tapering type and taper factor be 1/2 or 0.5.
Click OK. -
Step 14:
Now you have a tapered body.
Step 15:
Again edit the Flex1 feature. And this time choose Stretching. Choose stretch distance value to be 40. Click OK.
Step 16:
You have a stretched body. Any hole if present in the body will also be stretched.
