Make a grid in CATIA Sheet Metal using Louver feature
Here is a demonstration showing you the design of a simple grid in CATIA 3DExperience.
The Sheet Metal Design application, based on industry process features, allows you to create quickly a plate that you can bend and add stamps, dowels, bridges, etc.
In this video you will see how to use the Louver feature that allows you to design a grid in only 5 min!
Step 1: Video
Step 2: Create a plate
Open the Sheet Metal Design application
* the 3Dpart panel appears *
Create a 3Dpart called "Grid"
click on the global parameters
set the thickness to 0,3mm
set the radius to 1mm
* this will apply for all the features of your design *
Draw a centered rectangle 400*250mm
Exit the sketch
Create a wall with the profile
* the thickness is automatically set up to 0,3mm *
Step 3: Add holes to corners
Edit the sketch
Add R20mm fillets on the for corner
Select the centers of the fillets
Click on output feature
* in that way, the points will be shown when you exit the sketch *
* The points should be visible *
Create a hole Ø15mm using the point
* if the hole is not centered with the point, edit the sketch and add a coincidence between the 2 points *
Do the same with the 3 other holes
* tips: select the point first, then the plane or surface *
* The result should be this one *
Step 4: Create the Louver
Create a sketch on the plate's surface
Draw a centered rectangle 325x15mm and 110mm from center of the sketch
* like this *
Use the louver with the rectangle profile
Select the opening edge (bottom line)
Set 5mm in height
Angle a1 45deg
Angle a2 80deg
Click on OK
Step 5: Pattern the Louver
Go transform tab on the action bar
click on rectangular pattern
* select instances and length type *
Instances 10
length 220mm
* be sure that the direction is vertical *
* here is the result you should obtain *
Step 6: Refine the louver
Edit the sketch of the louver feature
Add fillets R7,5mm on the top corners
Exit the sketch
* the part will be automatically updated *
- end of tutorial
