Solidworks Tutorial Tap Bit M14 in Solidworks Modeling - BY SOLIDWORKS_EASY_DESIGN
Taps and dies are tools used to create screw threads, which is called threading. Many are cutting tools; others are forming tools. A tap is used to cut or form the female portion of the mating pair (e.g. a nut). A die is used to cut or form the male portion of the mating pair (e.g. a bolt).
Step 1: Solidworks Tutorial Tap Bit M14 in Solidworks Modeling - BY SOLIDWORKS_EASY_DESIGN
