TURBINE PUMP IMPELLER
THIS TUTORIAL SHOWS HOW TO 3D MODEL AN IMPELLER USING SOLIDWORKS SOFTWARE
  1. Step 1: sketch and revolved boss
  2. Step 2: lofted boss
    create 5 different sketches in 5 planes
  3. Step 3: circular pattern
    create a circular pattern of the lofted boss
  4. Step 4: revolved cut
  5. Step 5: extruded cut of the shaft hub
  6. Step 6: revolved cut to reduce the weight
    create a circular pattern of the revolved cut
  7. Step 7: move/copy body
    copy and translate the body to 500 mm away from the original
    in the second body make a revolved cut of the blades
  8. Step 8: move/copy body to the inicial position
    rotate the second body 45º and then translate it back to -500 mm. unselect the 'copy' box.
  9. Step 9: render
    add a material to the body
    then go to render tools and render it (note: go to render tools - options and decrease or increase the render quality from good to maximun or vice versa)
  10. Step 10: FINAL
