Tutorial: How to stop Round feature at Reference with Creo Parametric
A few steps for quick tutorial: How to create Round feature on edge Stopped by Reference point
Create custom model / shape
Create Point - this point will be reference point for Round feature
You can define Ratio or Real value for points position
I have choosed real value (125mm)
Create Round feature
Select Edge for Round feature and set custom value
In the Dashboard select "Switch to transition mode" button
Select left end of Round and then you can use Right mouse button >> Stop at Reference or ...
... or you can select drop down menu from Dashboard >> Stop at Reference
Select existing Point. Note; you can select existing Datum plane too for this reference
Step 11:
System create Round feature stoped at selected reference for you >> Finish Round feature
Step 12:
Created Round feature on edge Stopped by Reference point
Step 13:
You can create second round on same edge
