Tutorial: How to model parametric 3D text in PTC Creo Parametric and show design intent
Here is the short tutorial for you:
    Create base shape (Extrude feature = create your model)
    Create new Parameter (string) and set custom value (GRABCAD) >> Ok
    Create new Extrude feature >> in Sketch mode create Text >> (set) Use parameter >> Select Parameter... (button) >>> Insert Selected custom parameter from the list
    Note: 3D text is now parametric driven
    Finish Sketch and set value for Extrude feature
  5. Step 5:
    You can use Auto Round feature
  6. Step 6:
    Set custom value for Auto Round feature
  7. Step 7:
    System create Round feature for all edges
  8. Step 8:
    If you need to change 3D text ... you can select Parameters >> and set custom value for text Parameter.
  9. Step 9:
    Regenerate model = you can use CTRL+G
  10. Step 10:
    3D text is parametric driven - you can see new value from parameter
