Tutorial: How to model Tire in PTC Creo Parametric and show design intent
Toroidal Bend feature with PTC Creo Parametric 2.0
Create Extrude feature - base shape
Add Tire shape (add or remove material)
Create Pattern feature from added shape (create tread design)
Add some Rounds/Drafts (customize tread design)
Select Toroidal Bend feature
Select References Tab >> Solid Geometry / Define... >> Select Sketch plane and confirm Sketch
Create Profile Section with Coordinate system >> Confirm Ok
Select 360 degrees Bend from drop down menus. Choose Front and Back surfaces - system automatically will connect selected surfaces / references
... system automatically will connect selected surfaces / references
Finish Toroidal Bend feature (final geometry)
Step 11:
Finish your design for Tire (add some Revolve feature, Round, etc.)
Step 12:
Create 3D text - see Tutorial here: http://communities.ptc.com/blogs/vpalffy/2011/04/23/3d-text--offeset-from-the-surface
Step 13:
Create final rendering :)
