Tutorial - Intersect curve in Creo Elements/Pro aka Pro Engineer Wildfire?
Here is the tutorial.
Start Creo in Part mode.
Top Plane>>Sketch and use spline to make this entity. Exit the sketch.
Front Plane>>Sketch and use spline to make this entity. Exit the sketch.
Select the two splines while holding ctrl key. Now under Edit menu select Intersect.
Now the 3D curve or intersection curve is generated.
