Tutorial on Modeling Pipe Joint in Creo Elements/Pro aka Pro/Engineer Wildfire?
Here is the tutorial.
Start Creo.
Sketch >> Top plane.
Draw a circle of 80mm diameter.
Extrude it as surface by 200mm.
Offset the right plane by 200mm.
Sketch >> DTM1.
Draw a circle of 80mm at 200mm to the origin.
Extrude it as surface by 200mm away from origin.
Insert >> Boundary blend.
Select both edges of the pipes while holding down control key.
Step 11:
Under constraints change boundary conditions to Tangent for First chain.
Step 12:
Same for Last Chain.
Step 13:
Click OK and the surface is generated.
Step 14:
Insert >> Boundary Blend.
Step 15:
Again Select both edges while holding CTRL key.
Step 16:
For direction 2 select the edges of the boundary blend 1 while holding CTRL key.
Step 17:
Step 18:
Select all surfaces and then Edit >> Merge.
Step 19:
ClicK OK and the surfaces are merged into one.
Step 20:
Select the merge1 and then Edit >> Thicken.
Step 21:
Input thickness 2mm outside. Click OK.
Step 22:
Now the pipe joint is created using Boundary blend.
