Tutorial : makes drawing sheet format / size homemade
Step 1
This is the sheet that I input format, turn off the list "only show standard format" -
Step 2
Open the drawing file that has been previously created yourself -
Step 3
This is my modification sheet format -
Step 4
Right-click the sheet format> and select the edit sheet format -
Step 5
This modified image before and after modification -
Step 6
Once you have finished modifying select exit sheet -
Step 7
Then select save sheet format -
Step 8
Edit the file name your sheet,> then save
To open a sheet that has been modified see Step 1.
Hope it helps you all Bye ..
