Tutorial - Modeling cylinder head fins in SolidWorks?
Here is the tutorial.
Top plane>>Sketch.
Draw a square.
Extrude it by draft outwards.
Fillet the edges.
Top plane>>Sketch.
Convert the bottom face.
Offset the edge. Delete the converted edge or make it construction.
Top face>>Sketch.
Convert the face.
Offset the edge while making base construction.
Step 11:
Lofted surface.
Step 12:
Lofted surface between the sketches.
Step 13:
Hide the surface.
Step 14:
Right plane>>Sketch.
Step 15:
Draw a line.
Step 16:
Linear pattern it.
Step 17:
Extrude surface it in both direction.
Step 18:
While selecting surface-loft1 click trim surface.
Step 19:
Now using surface loft as trimming tool trim away the outer surfaces.
Step 20:
Thicken.
Step 21:
Thicken the surface.
Step 22:
Repeat the same step for other edges.
Step 23:
Fillet all faces.
Step 24:
We have the fins created.
