Tutorial - Modeling USB Head in SolidWorks Part 3?
Here is the third part.
Select the cut feature and then linear pattern.
Select this edge about X-axis.
Reverse the direction and 6 times at a distance of 2.032mm. Uncheck Geometry pattern.
Circular pattern.
Select the circular edge and linear pattern as teh feature to pattern by 4 times.
Now the USB head is ready.
Select this face >> Appearence.
Select face.
Select all these face and apply polished steel appearence to them and click OK.
Select this face >> Boss-Extrude2.
Step 11:
Select all these features and apply textured plastic PW-MT11000 appearence to them.
Step 12:
Now our model is ready. We need to configure render settings and scene settings.
Step 13:
Click Edit scene.
Step 14:
Change Flooor to XZ with 10mm offset.
Step 15:
Click Edit option and Edit the image option here.
Step 16:
Change the Scene to Background-Ambient White.
Step 17:
Front Plane >> Sketch.
Step 18:
Draw a line with Origin as mid-point.
Step 19:
Extrude surface by mid plane by ~285mm.
Step 20:
Select surface and then Appearence >> Surface-Extrude.
Step 21:
Apply Polished Oak 2d Appearence under wood.
Step 22:
Hide the property manager and Isometric view.
Step 23:
Zoom in and adjust the USB to center of screen.
Step 24:
Change view type to Perspective.
Step 25:
Click Final Render.
Step 26:
We have the rendered image.
Step 27:
For different setting we have this rendering image.
