Tutorial - Using surface cut feature for bossing text in SolidWorks?
Here is the Tutorial.
Start SolidWorks in Part mode.
Top plane>>sketch and make such profile.
Extrude it by 100mm.
Front plane>>sketch.
Make a center line first and then use text tool to type this text using centerline as curve.
Use boss-extrude tool and extrude it to the the surface and select the body face. Uncheck the merge result.
Offset the surface used in previous step by 10mm.
Choose the cut with surface and change the direction to inside the surface. Click OK.
Hide the offset surface.
Insert>>feature>>combine.
Step 11:
Select add in operation type and select all bodies to combine. Click OK
Step 12:
And we have bossed the text using cut-surface feature.
