How to use a part sketch as an assembly refference in Catia? Mutlucan Tokat 17 May, 2015 05:33 AM I want to make coincidence constraint with center of gear and and point on 1.png in attachment. However in assembly mode the point disappears. How can i do that? 2.png 1.png 1 Answer özgür kesebir Answered on 17 May, 2015 12:58 PM second image is true one. you must use point as non construction element. Insert also a point into the gear center in gear part file. Then use coincidence command in assembly mode.
