2nd tutorial on how to model a wide-chord fan for a turbofan engine in CATIA
Steps 1 thru 15.
    1. Create the circle on the yz-plane. Exit sketcher. Be sure to name your sketches, otherwise it's difficult to keep track of everything.
    2. Enter sketcher on the yz-plane and create the spline shown. Exit sketcher.
    3. Create the following spline on the yz-plane. Exit sketcher.
    4. Create the following spline on the zx-plane. Exit sketcher.
  5. Step 5:
    5. Create the following spline on the zx-plane. Exit sketcher.
  6. Step 6:
    6. Extrude the first spline.
  7. Step 7:
    7. Extrude the 2nd spline.
  8. Step 8:
    8. and the 3rd...
  9. Step 9:
    9. and the 4th... You should end up with a kind-of box.
  10. Step 10:
    10. Create an intersection curve as shown.
  11. Step 11:
    11. Create another intersection curve.
  12. Step 12:
    12. Create the plane as shown.
  13. Step 13:
    13. Create 2 intersection points. Click the button shown to add the 2 curves.
  14. Step 14:
    14. Enter sketcher on the plane you just made and make the following shape. The two endpoints should be coincident with the two intersection points you just made.
  15. Step 15:
    15. Make another plane as shown.
