Tutorial: How to model a fan blade in Catia V5?
Tutorial to model a fan blade in Catia V5
Create the base on which the blades will be made.Create a point on the lower edge.
Similarly create a point on the upper edge at a certain lateral distance from the first point.
Create a 3d line between the points and choose support as the lateral face of the padded object.
Switch to GSD Workbench
Extrude the line along zx plane
Invoke a sketch on xy plane
Sketch the shape of the blade and make the end coincident with the edge of the padded object.
Exit the sketch
Extrude the sketch with reference as the xy plane
Split out the unnecessary parts by using "split" command
Step 11:
Hide the extruded part which is not necessary
Step 12:
Switch to mechanical part design workbench
Step 13:
Insert->surface based features->thick surface
Step 14:
Provide some thickness. Click OK
Step 15:
Tools->hide->all surfaces
Step 16:
Click on circular pattern
Step 17:
Fill with appropriate parameters
Step 18:
After the pattern you will get the required object.
