How to optimize time during sketching in Pro-E/Creo ??
Well I've started with sketching tips in pro-e/creo, which often come handy when I use pro-e/creo elements.Then I'll move on to some feature base tips.So lets not waste time and get started.Its easy and will take minimal time...
first off all I've just drawn a random stuff so that you can easily get go with the command.You can use for intricate drawings also.
Ok go to sketch mode...
draw what you want... -
Now select all the stuff that you have drawn...
Nextly right click in space(hold right click for sometime) and a menu appears...
Select "modify" from it... -
Now a pop-up appears where you can modify all the relevant dimension at one place....Cheers
