Tutorial - Modeling Flower in SolidWorks using Surfacing?
Here is the tutorial.
Front Plane >> Sketch.
Draw a spline and center line.
Revolved surface it.
Top plane >> Sketch.
Draw this profile.
Select Trim surface under surfaces tab.
Trim the outside surface of the profile.
Thicken under surfaces tab.
Select the leaf and then thicken it.
Reference Geometry >> Axis.
Step 11:
Select top plane and origin. Click OK.
Step 12:
Circular pattern.
Step 13:
Select the thicken body as the body to be patterned about the axis 6 times.
Step 14:
Step 15:
Draw a circle.
Step 16:
Extrude it.
Step 17:
Click Dome under features tab.
Step 18:
Top face of the extrusion and dome it.
Step 19:
We have the flower body created.
