Tutorial - Modeling Nut in Creo Element aka Pro/E?
Here is the tutorial.
    Sketch >> Top plane.
    Draw a polygon with circle of 17mm dia and a circle of 20mm dia.
    Extrude it by 10mm.
    Sketch >> Right plane.
  5. Step 5:
    While taking the edges as the references Draw a Triangle with angle of 30º.
  6. Step 6:
    Revolve it about the center axis with remove material.
  7. Step 7:
    For other side repeat the same operation.
  8. Step 8:
    Insert >> Helical Sweep >> Cut.
  9. Step 9:
    Click Done.
  10. Step 10:
    Select Right plane.
  11. Step 11:
    Click Okay and then default.
  12. Step 12:
    Now we have to define the sweep profile i.e. the profile along which the helix will be generated.
  13. Step 13:
    Draw a center line about the horizontal axis.
  14. Step 14:
    Draw this line at 9.5mm to horizontal axis.
  15. Step 15:
    Exit the sketch and input pitch value = 2.5mm. Click OK.
  16. Step 16:
    Now draw the Cutting profile. This be Iso triangle.
  17. Step 17:
    Exit the sketch and the material direction be inside.
  18. Step 18:
    Click OK. Now we have the nut generated.
  19. Step 19:
    If you want to add a chamfer to the edge after helical cut operation, drag the insert here above the cut id.
  20. Step 20:
    Now create the chamfer on the edges.
  21. Step 21:
    Drag the insert here back to below the cut id.
  22. Step 22:
    We have the nut generated.
