Creating Thin-Walled Container Cover in AutoCAD using CSG Technique
SOLID MODELLING USING CONSTRUCTIVE SOLID GEOMETRY (CSG).
-Use AutoCAD to create a thin walled (2 mm wall thickness) container cover and then slicing it.
-Diameter of the through bore is 50 mm and depth of round and rectangular portions are each 40 mm.
-Use R5 for filles and 2x2 mm for chamfers
