Tutorial - Making iPhone 4s in SolidWorks Part 1?
Here is the tutorial.
Start SolidWorks.
Front Plane >> Sketch.
Draw this.
Fillet corners.
Extrude it as thin feature of .6 and mid plane by 6.17mm.
Chamfer the edges by 0.25 at 45º.
Right plane >> Sketch.
Draw a rectangle.
Draw on the upside also.
Curves >> Split line.
Step 11:
Select all faces. And click OK.
Step 12:
Now the split faces have been generated.
Step 13:
Front plane >> sketch.
Step 14:
Select sketch of Extrude1 and click Convert entities.
Step 15:
Extrude it by 9.34mm.
Step 16:
Fillet the edges by 0.25mm.
Step 17:
Front face >> Sketch.
Step 18:
Draw circle at vertical to origin.
Step 19:
Step 20:
Select the front face and click OK.
Step 21:
Select dome tool.
Step 22:
Select the split face and dome it by 0.50mm inwards.
Step 23:
Step 24:
Draw a rectangle at the center of circular face.
Step 25:
Fillet it's edges by 0.65mm and then offset it by 0.40mm
Step 26:
Split line and select the domed surface. Click OK.
Step 27:
Step 28:
Draw a slot.
Step 29:
Extrude cut by 1mm.
Step 30:
Chamfer the edge by 0.775 and 0.80mm.
Step 31:
Here is second part
http://grabcad.com/questions/tutorial-making-iphone-4s-in-solidworks-part-2
