Tutorial - Making iPhone 4s in SolidWorks Part 2?
Here is the second part.
    Front face >> Sketch.
    Draw a circle of 4.8mm dia.
    Extrude cut by 1mm at draft of 50º.
  5. Step 5:
    Convert the edge.
  6. Step 6:
    Extrude it by 0.25 at 50º draft.
  7. Step 7:
    Front face >> Sketch. Hide the previous extrusion.
  8. Step 8:
    Draw a circle of 2mm dia.
  9. Step 9:
    Split line and select the inner face.
  10. Step 10:
    Hide the extrusion body.
  11. Step 11:
    Dome the inner surface by 0.40mm.
  12. Step 12:
    Top face >> Sketch.
  13. Step 13:
    Draw a slot.
  14. Step 14:
    Extrude cut it by 0.50mm.
  15. Step 15:
    Inner face >> Sketch.
  16. Step 16:
    Offset the edge by 0.25mm.
  17. Step 17:
    Extrude it by 1.10mm without merging result.
  18. Step 18:
    Chamfer the edge by 0.20mm at 45º.
  19. Step 19:
    Left face >> Sketch.
  20. Step 20:
    Draw a rectangle and fillet its's corners.
  21. Step 21:
    Draw another circle.
  22. Step 22:
    Draw 2nd circle.
  23. Step 23:
    Extrude cut them by 0.50mm.
  24. Step 24:
  25. Step 25:
    Draw a slot.
  26. Step 26:
    Draw two circles.
  27. Step 27:
    Extrude them by 1.10mm.
  28. Step 28:
    Chamfer the edge by 0.2mm at 45º.
  29. Step 29:
    Circular face >> Sketch.
  30. Step 30:
    Draw this sketch.
  31. Step 31:
    On lower circle draw this sketch using slot.
  32. Step 32:
    Extrude cut by 0.2mm.
  33. Step 33:
    Here is third part.
    http://grabcad.com/questions/tutorial-making-iphone-4s-in-solidworks-part-3
