Tutorial - Making iPhone 4s in SolidWorks Part 5?
Here is the fifth part.
Inner face >> Sketch.
Draw a rectangle.
Extrude it by 1.50mm.
Front face >> Sketch.
Change vision to hidden line visible. Convert the edge and convert it to construction. Draw a rectangle taking it reference.
Linear pattern it at a distance of 0.5mm 30 times.
We have the pins.
Split Line and select this face. Click OK.
Now the pins are generated.
Right face >> Sketch.
Step 11:
Draw a slot.
Step 12:
Split line and project it on right face.
Step 13:
The slot face >> Sketch.
Step 14:
Draw a circle.
Step 15:
Extrude cut by 1.8mm.
Step 16:
Step 17:
Draw a rectangle.
Step 18:
Fillet the edges.
Step 19:
Curve >> Split line.
Step 20:
Project it on Front face.
Step 21:
Back face >> Sketch.
Step 22:
Use spline tool and make this sketch.
Step 23:
Project it on the back face.
Step 24:
We have iPhone 4s in SolidWorks.
Step 25:
Whow the boss-extrude.
Step 26:
Now apply different appearance to different faces and iPhone 4s is ready.
