Tutorial - Making iPhone 4s in SolidWorks Part 4?
Here is the fourth part.
Split line and project them on back face.
Inner face >> Sketch.
Convert the inner edge and extrude cut it by 0.50mm.
Dome it by 0.4mm.
Circular face >> Sketch.
Convert the edge.
Extrude it by .10mm and uncheck Merge result.
Bottom face >> Sketch.
Draw a slot.
Mirror it about a center line on origin.
Step 11:
Extrude cut by 1mm.
Step 12:
Left face >> Sketch.
Step 13:
Draw this slot.
Step 14:
Split line and then select inner face.
Step 15:
Step 16:
Draw a rectangle.
Step 17:
Extrude cut by 2.5mm.
Step 18:
Chamfer the cut edge by 0.15mm at 45º.
Step 19:
Step 20:
Draw two circles.
Step 21:
Split line and select bottom face.
Step 22:
Step 23:
Draw a 5 side polygon and construct star.
Step 24:
Repeat same step for other circular face. Make polygon construction.
Step 25:
Extrude cut by 0.50mm.
Step 26:
Here is fifth part.
http://grabcad.com/questions/tutorial-making-iphone-4s-in-solidworks-part-5
